Heeft iemand ervaring met drijfstangen of advies van horen vertellen/gelezen?
Ik wil namelijk drijfstangen aan gaan schaffen maar helemaal geen informatie daar over.
Het gaat om deze:
Application:
EP82 GT/EP91 Glanza 4efte
Description:
Scat 4e Forged Conrods with ARP Bolts for all Toyota Starlet EP82 and EP91 Turbo models.
Scat has used its 45 years of innovation and creativity to develop a broad line of connecting rods that are superior in strength, quality and reliability. All of the connecting rods are made from their famous 2-piece forging for increased strength. They are finished and balanced into complete sets at their state-of-the-art facility in Redondo Beach, California.
Specifications:
Made from 4340 aircraft quality material.
Fully profiled for stroker engines.
Shipped with ARP bolts.
Precision sized to tightest specifications.
Balanced to ±1 gram at SCAT.
These conrods are ideal for those rebuilding/forging engines allowing the old, OEM weaker rods to be replaced with something that is a lot stronger, ideal for higher revving applications.
Application:
Description:
THS 4efte Forged Conrods with ARP Bolts for all Toyota Starlet EP82 and EP91 Turbo models.
These 4efte specific THS H-Beam rods are made from high quality forged steel offering extreme reliability and stability over the standard Starlet rods. They come with a doweled cap design and 5/16" ARP 2000 Rod bolts.
These rods will handle in excess of 600bhp/9000rpm.
Specifications:
Length - 118mm
Journal - 43mm
Pin - 18mm
Weight - 380grms each*
Dowelled Cap for Precision fit.
Balanced to within +/- 1 gram.
All big and small ends are finished with SUNNEN cross grinder.
Bronze wrist pin bushings are made to withstand higher impact force.
Forged steel, vacuumed to remove impurities.
All surfaces are 100% machined.
Shot peened to relieve stress.
Multi Stage Heat Treated.
* Weight of rod is without bolts.
Each set of rods are in matched sets and are a direct fit for the 4efte Starlet engine. Ideal for those building forged engines or for those rebuilding worn engines looking for a cost effective replacement for the weaker OEM conrods.
