Auteur Topic: Foto's EP8*  (gelezen 117144 keer)
Offline Red Hot
Foto's EP8*
« Gepost op: oktober 22, 2006, 16:38:18 »
Plaats hier foto's van mooie EP8*
Offline Red Hot
« Reactie #1 Gepost op: oktober 22, 2006, 16:38:35 »
Offline Red Hot
« Reactie #2 Gepost op: oktober 22, 2006, 16:39:14 »
Other information includes:
Engine Modifications - dump pipe, 2.5" mandrel bent exhaust with twin stainless cannons mounted in centre, aftermarket wastegate, hybrid front mount, mines computer, straight cut 1st and 2nd gears, brass button clutch, Cusco short shift, Blitz bov, boost controller, Blitz boost cut defender, bigger leads, boot mounted battery, custom stainless windscreen washer bottle and oil catch can.
Exterior Modifications - Toms front bar (modified), Toms sides, Toms wing, custom grille, custom rear bar, custom twin headlights, chrome M3 mirrors w/ indicators, stainless mesh, full respray, shaved rear wiper, shaved aerial and all locks, lipped and rolled gaurds.
Suspension / Braking Details - Nitrex race coilovers, adjustable camber tops/camber pins, 5 cusco strut braces (radiator, top front, lower front, top rear, lower rear). Adjustable panhard rod, braided brakelines, aftermarket brake booster.
Wheels - 18 x 7.5" Alba Bertha's w/ 215/35 falken tyres
Interior Modifications - Full retrim in "custard" synthetic leather, removed rear seat, custom floors, custom door trims, Isotta steering wheel, gear knob and handbrake cover all in matching custard leather.
Stereo/Security Details - Clarion MD player, 5.25" kevlar splits, 2 x Schneider dual voice coil 15" subs, 4 channel amp, full vision alarm system, purple neons.
This car has been seen around the queensland show circuit at the 2004 jamboree (winner of best body kit and best 1990-1994 2 door), autosalon (editors choice award), and smaller car shows (Best street car, top 2 door etc). This car has also been published as a feature in car in issue 128 of Hot 4's. This car is a really tidy car which has been maintained really well.
I am currently forced to sell the car due to future study commitments which limit the amount of time that i am able to spend with the car, hence i feel that the car could be better enjoyed with another owner.
$24,000. All offers considered
Offline Red Hot
« Reactie #3 Gepost op: oktober 22, 2006, 16:39:49 »
foto's foetsie...
« Laatst bewerkt op: november 23, 2006, 22:46:47 door Red Hot »
Offline Red Hot
« Reactie #4 Gepost op: oktober 22, 2006, 16:40:18 »
Offline Red Hot
« Reactie #5 Gepost op: oktober 22, 2006, 16:40:45 »
Offline Red Hot
« Reactie #6 Gepost op: oktober 22, 2006, 16:41:20 »
Iemand nog wat carbon over. Zou je het ook zo kunnen gebruiken>
Offline Red Hot
« Reactie #7 Gepost op: oktober 22, 2006, 16:41:45 »
Offline Red Hot
« Reactie #8 Gepost op: oktober 22, 2006, 16:42:21 »
Offline Red Hot
« Reactie #9 Gepost op: oktober 22, 2006, 16:42:48 »
Citaat
*5E balanced/blueprinted block
*Ross pistons/ BDG forged rods
*WEPR custom ported and polished head with 5 angle valve job
*custom uprated cams
*hybrid Garrett GT25/40R turbo (1.8bar boost)
*WEPR stainless manifold
*WEPR front mount intercooler
*WEPR front mount intercooler piping
*WEPR 3" downpipe
*WEPR 3" side angled exhaust system
*Turbonetics Racegate w/external dump tube
*Microtech stand alone ECU
*custom aluminium big bore intake manifold
* 450cc injectors
*Vortech fuel preassure regulator
*Nos in-line high preassure fuel pump(not pictured)
*WEPR fuel surge tank(not pictured)
*Blitz blow off valve
*WEPR oil catch can
*WEPR battery re-location kit
*WEPR dual core radiator
*WEPR high volume radiator fan
*NGK ignition wires
*NGK irridium 8 plugs
*Exedy 3 puck high torque clutch/preassure plate
*Tien full adjustable suspension
*cusco lower arm bar
*front factory strut bar
*rear factory 3-point strut bar
*WEPR rear 4 point tub brace
*stainless steel brake lines
*cucso brake pump stop
*Endless brake pads
*uprated brake rotors (not pictured)
*WORK rsb 15" alloys (not pictured)
*Bridgestone potenza G3 tires
*Trust warning meter/memory funct. boost/EGT/air-fuel/water temp guages
*HKS turbo timer
*Trust Profec B spec II boost controller
*full Tom's body kit
i know i am forgetting a few mods but thats it for now. future more include a nitrous system and more boost along with bigger brakes. the car is completely stripped..strict diet. the dash is only a shell...everything else has been taken out. factory harness was ripped out and custom lightweight harness was wired in (you be suprised as to how much the factory harness weighs). managed to drop about 60kg's.
Offline Red Hot
« Reactie #10 Gepost op: oktober 22, 2006, 16:43:23 »
Citaat
colour is alfa romeo gta pearl white.
Also there is red house of kolor flakes in with the laquer
Offline Red Hot
« Reactie #11 Gepost op: oktober 22, 2006, 16:43:49 »
Offline Red Hot
« Reactie #12 Gepost op: oktober 22, 2006, 16:44:46 »
Offline Red Hot
« Reactie #13 Gepost op: oktober 22, 2006, 16:45:16 »
Offline Red Hot
« Reactie #14 Gepost op: oktober 22, 2006, 16:45:40 »
Offline Red Hot
« Reactie #15 Gepost op: oktober 30, 2006, 15:31:34 »
Ja, daar is ie weer. Nu met een nieuw interieur en wat nieuwe vrouwen :D
« Reactie #16 Gepost op: oktober 30, 2006, 15:39:22 »
:jumpy:  :drool:  ^O^
« Laatst bewerkt op: januari 01, 1970, 01:00:00 door Ronald »
Sagittarius
« Reactie #17 Gepost op: oktober 31, 2006, 13:37:03 »
jah jamie is een geluksvogel lol. ik heb hem al gevraagd wat rhiannan (zn vriendin) ervan vindt lol
« Laatst bewerkt op: januari 01, 1970, 01:00:00 door Sagittarius »
« Reactie #18 Gepost op: november 02, 2006, 23:15:01 »
ik vond deze op het australische Starlet forum... daar staan nog veeeel meer mooie Starlets
Offline Red Hot
« Reactie #19 Gepost op: november 23, 2006, 22:24:24 »
Offline Alex
« Reactie #20 Gepost op: november 23, 2006, 22:42:32 »
Vette shit. Ik had alleen voor mn photoshoot dat afval even in een zak gedaan en weggezet ...
« Laatst bewerkt op: januari 01, 1970, 01:00:00 door Alex »
EP71 2E-TELU
Offline Red Hot
« Reactie #21 Gepost op: november 23, 2006, 22:51:48 »
Offline Red Hot
« Reactie #22 Gepost op: november 23, 2006, 22:56:12 »
Offline Red Hot
« Reactie #23 Gepost op: november 27, 2006, 18:57:27 »
Offline Red Hot
« Reactie #24 Gepost op: december 11, 2006, 15:40:52 »
Citaat van: "Alex"
Vette sh*t. Ik had alleen voor mn photoshoot dat afval even in een zak gedaan en weggezet ...
Hij heeft naar je geluisterd Alex ;)
