Auteur Topic: Speaker replacement for '95 Paseo?  (gelezen 705 keer)
Offline RyanCaleb
« Gepost op: september 20, 2017, 08:48:22 »
Hi all,
I have just obtained a '95 Paseo with blown out door speakers. The Factory radio has been replaced with an after market Sony. I am wondering on how difficult it would be to replace/upgrade the door speakers. I am not looking for a sub, only just door speakers that would hopefully sound pretty decent.
I'm assuming that it should be fairly easy to replace. Just pop open the grills and wire the new speakers up the same way. But I don't know exactly how many speakers are in the paseo, or what size to get.
I've tried googling, but I can only find instruction for just generic cars.
So basically the info I need to know is:
-Can I just install new speakers into the doors without anything too complicated?
-What size, and how many speakers does the Paseo have (I think only 2)?
-Is there any recommendations on what speakers would be a good fit (I am not trying to spend over $100)?
Thank you very much!
« Laatst bewerkt op: september 20, 2017, 09:37:23 door Rage »
Re: Speaker replacement for '95 Paseo?
« Reactie #1 Gepost op: oktober 19, 2017, 17:51:23 »
You are talking about door speakers? Starlets do not have those.
And the 2 small speakers for behind those small grilles, those are 10cm speakers and easily replaced.
« Reactie #2 Gepost op: oktober 19, 2017, 19:42:13 »
It's about a Paseo  ;)
Better take a look first (at the size) and then buy the same size speakers, normally it's easy to replace them, on a standard radio 80 till 120 watt speakers will do fine, and they are not that expensive.
Edit:
Maybe this will help :)
www.sonicelectronix .com/toyota-paseo-1992-car-speakers.html
« Laatst bewerkt op: oktober 19, 2017, 20:15:05 door Patrix »
