Auteur Topic: D1 spec VSD II  (gelezen 2344 keer)
Offline RicoW
  • Registered Traders
  • Skyline From Hell
D1 spec VSD II
« Gepost op: september 30, 2015, 21:38:24 »
Te koop aangeboden:
D1 spec VSD II
Staat onderdeel:
nieuw
Prijs:
50
Extra Info:
This ignition amplifier incorporates both the CDI and transistor method ignition to provide optimum spark duration and maximum voltage output, resulting in crisper throttle response and a smoother engine powerband The VSD-II integrates Capacity Discharge Ignition (CDI) and transistor ignition technology to offer improved throttle response and smoother engine performance by providing optimal spark duration and maximum voltage output. The CDI technology provides maximum voltage by transferring all stored energy in the capacitor to the ignition coil so the ignition current can build quickly, making the VSD very effective at higher revs where a normal spark would diminish. The strong,rapid spark prevents high rpm ignition miss that reduces peak power. The transistorized method generates high voltage by using transistors to cut off current to the coil, allowing a long energy discharge. This longer spark duration allows the Twin Power to improve lower RPM throttle response and torque. The Twin Power produces a spark output that is typically 1.5-2.5 stronger than a stock ignition system and consumes about 35% less power than other ignition amplifiers.
oftewel: nooit meer bougievonkjes bijvullen
Foto's:
Contact info:
PM Mail
Zevenbergen
Alleen ophalen.
