Auteur Topic: Foutcodes Starlet  (gelezen 6455 keer)
Offline Evil Genius
  • Berichten: een heleboel
Foutcodes Starlet
« Gepost op: augustus 18, 2013, 09:29:10 »
Citaat
Code: 12
Signal: RPM Signal
Diagnosis: No G or NE signal present for 2 seconds during cranking
Common Trouble Area :  Open G circuit, Open, short in G or NE circuit.  Distributor, ECU
Code: 13
Signal: RPM signal
Diagnosis: No NE signal for 50msec at 1000rpm.
Code: 14
Signal: Ignition
Diagnosis: No IGF signal to ECU for 4 consecutive IGT signal during engine running
Common Trouble Area: Open/short in IGF/IGT signal from igniter to ECU, Igniter malfunction, ECU
Code: 21
Signal: O2 sensor
Diagnosis: Open/short in heater circuit of oxygen sensor for 0.5 seconds. Amplitude of O2 sensor reduced to 0.35-0.70V continuously for more than 60 seconds
Common Trouble Area: O2 sensor, vacuum sensor, ECU
Code: 22
Signal: H2O temperature sensor
Diagnosis: no signal at THW
Common Trouble Area: water temperature sensor, ECU
Code: 24
Signal: Intake Air Temp sensor
Diagnosis: No signal at THA
Common Trouble Area: Intake air temp sensor, ECU
Code: 25
Signal: A/F Lean
Diagnosis: O2 sensor output in less than 0.45 volts for at least 90 seconds when O2 sensor is warmed and 1500 rpm or above.
Common Trouble Area: open injector circuit, lack of fuel pressure, gnition system, Vacuum sensor, O2 sensor,ECU
Code: 31
Signal: Vacuum sensor
Diagnosis: No signal at Vacuum sensor (PIM)
Common Trouble Area: Vacuum sensor to ECU
Code: 33
Signal:  ISCV (Idle speed control valve)
Diagnosis: Open or short in ISCV circuit
Common Trouble Area: ISCV Valve
Code: 41
Signal: Throttle Position sensor
Diagnosis: No signal for 0.5 seconds or more at ignition ON. (VTA)
Common Trouble Area: TPS,ECU
Code: 42
Signal: Vehicle Speed Sensor
Diagnosis: No speed sensor signal to ECU when loaded driving condition with engine speeds 2000 to 5000 rpm.  for 8 seconds or more.
Common Trouble Area: VSS,ECU
Code: 43
Signal: Starter
Diagnosis: No starter signal to ECU when cranking in TEST mode. Terminal STA on ECU
Common Trouble Area: starter signal circuit, starter relay,ignition switch
Code: 51
Signal: Switch condition signal
Diagnosis: Displayed when A/C is on when TE1 and E1 connected in test mode
Common Trouble Area: A/C switch,Accelerator pedal, cable,ECU
Code: 52
Signal: #1 Knock sensor
Diagnosis:  no KNK1 signal to ECU
Common Trouble Area: knock sensor (looseness), malfunctioning knk sensor
Code: 53
Signal: #2 Knock sensor
Diagnosis: no KNK2 signal to ECU
