http://www.rambeyracing.com/index.php?id=7&child=1Vehicle: 1998 Drag race starlet /glanza EP91.
Power : Fase 1 : 560hp @ wheels - fase 2 850hp @ wheels.
Lubrication: Normal wet sump , w. MOROSO drag pan.
Tires: Front : Mickey Thompsom.
Rear: M/H Skinnies.
Engine: 5sgte 4-cylinder 2,0L.
Head: 3sgte Small port.
Driveline: OEM gearbox w. iron forks an KAAZ LSD diff.
Blown: Garrett GT42 Ball bearing turbo w. horn
Fuel delivery: AEROMOTIVE A1000 pump SUMMIT mic10 and mic100 filters.
4x 1600cc Bosch injectors TURBOSMART FPR 1200 regulator.
Ignition system: 4x bosch single coil ignitors.
Intake: Spec BEYER INLET manifold, 80mm throttle body.
Exhaust: Spec BEYER EX manifold w. 2x TURBOSMART 38mm wastegates.
Engine manegement: KMS MD35 w. KMS inj driver
Suspension & brakes: D2 fully Drag coilover suspension and Willwood big brake caliber set.
Wheels: Weld racing front - Exospeed rear
Safety / Harness: Sparco harness , Simpson chute , cromemoly rollgage
http://www.youtube.com/watch?v=1ycJreNUdnghttp://www.youtube.com/watch?v=Ike-lFh4-2YRonald.
